Hai
This is a discussion on Hai within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; how to connect samsung galaxy wonder gt-i8150 to home wifi network...
Thread: Hai
    Android Lurker mohammed18's Avatar
    Jul 2012
    Smile Hai
    Android Lurker Alzena's Avatar
    Jul 2012
    Go to settings - wireless and mobile networks - and turn wifi on. And then it will show you the available wifi networks. Choose yours, write the password and connect. These introductions are for android 2.3 Gingerbread. If you use ICS you can turn wifi on from task bar and it will show you the networks. Hope I helped
    Sent from my GT-I9300 using Android.net
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site.
