Samsung Galaxy S2 Not Charging When Phone is On
This is a discussion on Samsung Galaxy S2 Not Charging When Phone is On within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi, First of all I'm new to the forum. I just updated my Samsung Galaxy S2 (GT-I9100G) to ICS 4.0.4 Unfortunately since I have updated ...
Thread: Samsung Galaxy S2 Not Charging When Phone is On
    Android Lurker wolaa's Avatar
    Aug 2012
    Exclamation Samsung Galaxy S2 Not Charging When Phone is On
    Unfortunately since I have updated my phone, it is not charging when the mobile is switched on. It is also not being recognized when plugged to the computer via the USB cable supplied. I have read that if you switch off the mobile phone it should charge and I can confirm that when it is switched off the mobile will start charging, so I know that the USB port is not damaged. I also read that the best thing is to backup the necessary data and do a factory reset. I've done the hard reset but still no luck!
    Is there anyone who has the same issue or any advises?
    Android Lurker notyelfox's Avatar
    Dec 2011
    I don't have that issue with mine but my signal seemed to drop. Do you know how to change internet settings
    Sent from my SPH-D710 using Android.net
    Android Lurker maira's Avatar
    Sep 2012
    hi wolaa.. i also had the same kind of issue on my GS2, but i still remember that time the problem was got resolved by the hard reset only. i think your way of performing a reset would be different thats why the problem is still there. you can try this How to hard reset Samsung Galaxy S2 hope it will work for you. please let me know if it didn't work. coz i have few more tips and tricks for an issue like this. thanx
  1. Phone no longer charging with USB charger
    By DoctorCamila in forum LG Ally Help
    Last Post: 10-19-2011, 06:06 AM
  2. Phone not charging?
    By Rosesandlilys in forum LG Ally Help
    Last Post: 08-29-2011, 10:10 AM
  3. Replies: 0
    Last Post: 02-22-2011, 11:21 PM
  4. Slight humming coming from charger while phone is charging?
    By TheThumb14410 in forum LG Ally Help
    Last Post: 11-24-2010, 12:29 PM
  5. Need Help Charging Phone
    By swimmerchick5891 in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 05-03-2010, 04:59 PM
galaxy s2 is not charging
galaxy s2 not charging
galaxy s2 not charging when turned on
galaxy s2 stopped charging
my samsung galaxy s2 is not charging
phone not charging galaxy s2
samsung galaxy 2 not charging
samsung galaxy s2 charging problems
samsung galaxy s2 not charging
samsung galaxy s2 phone not charging
samsung s2 charging problem
samsung s2 charging problems
samsung s2 not charging
why is my galaxy s2 not charging
why is my samsung galaxy s2 not charging
