I just bought used N12 tablet thru online.. N12D81206HZ12652
my son was play around with that tablet now the tablet was lock have massage 'too many pattern attempts'
i was call/massage the seller a few time but not answers
any one can help me..
This is a discussion on 'Too Many Pattern Attempts' within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I just bought used N12 tablet thru online.. N12D81206HZ12652 my son was play around with that tablet now the tablet was lock have massage 'too ...
Usually the default pattern unlock is 8888 or 0000, but it may be different on your device. You could try a ten min battery pull to see if that resets it. Or you can't remove the battery on this tablet, you may need to contact the manufacturer to have them explain how to reset it. Google the manufacturers name to get their customer service number.
Good luck!
tap'n
I used play store app called "Screen lock bypass", it can temporary unlock the device. https://play.google.com/store/apps/d...reenlockbypass
