Android Lurker
HELP!! "USB Storage Blank or Has Unsupported File System"
Hi guys...
Really need help here.
Currently I have this problem: "USB Storage blank or has unsupported file system".
Therefore I am not able to view, safe, or use any file from my SD Card and USB Storage.
I only depends on the system storage right now which only got 2GB.
Whenever I touch the (!) icon, it goes "Format USB Storage". Which....I'm not prefer of doing it at the moment
bcoz there is important data in there.
Is there any solution for this kind of problem?
Or do I need to go n check with the mobile service center?
I'm using Galaxy Note, Android version 4.0.4
09-29-2012 07:31 AM
# ADS
Android Lurker
Originally Posted by
mochalatte
Hi guys...
Sent from my GT-N7000 using Android.net
Android Lurker
I had the same problem please help in solving this problem
Rescue Squad
I would try to put the microSD in a reader and plug it into a PC to see if you can recover the files. Then I would format for FAT32 and see if that works in your phone.
ASUS Transformer 16GB with Keyboard Dock - Cornerstoned and ICS-ified
iP*one 4
Just once I want someone to call me Sir without adding you're making a scene.
- Homer Jay Simpson
