Nexus S Doesn't Turn ON
This is a discussion on Nexus S Doesn't Turn ON within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi all, I was using some app yesterday and the battery was around 40% before I started it. After a small time, the phone got ...
Thread: Nexus S Doesn't Turn ON
    Android Lurker M.Shabbir's Avatar
    Oct 2012
    Hi all,
    I was using some app yesterday and the battery was around 40% before I started it. After a small time, the phone got OFF and since then it has not shown any signs of turning ON.
    I have tried the charger but sometimes the battery charging icon on the screen gives a glimpse showing vertical bars which means its charging but then its off again. Whole night I have been charging my phone, the charger was hot too, but the phone is still not ON.
    Any ideas whether its a software issue or hardware or whether its because of that application (The application was downloaded by google play though) or can it be the USB wire problem as my charger is the USB cable one not a separate one and I am using the same cable for both.
    Waiting for urgent responses.
    Thanks in advance
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site. Hopefully, someone comes along soon with some help.
    519 times
    Welcome aboard! Hang in there for the answer to your problem - it will come.
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Welcome to the forum! How long have you had the phone? Did this just start happening after you downloaded this app? What's the name of the app?
    tap'n
    Android Lurker jgf52's Avatar
    Dec 2012
    happened to me too, nexus s, won't turn on, happened after i tried switching batteries though, no recent software changes....wonder if there's any way to test the power button?
  1. Replies: 0
    Last Post: 09-13-2012, 11:19 AM
  2. Replies: 1
    Last Post: 12-05-2011, 05:48 PM
  3. Replies: 0
    Last Post: 10-21-2011, 09:33 AM
  4. My backflip.. doesn't turn off?
    By xStyle in forum Motorola Backflip
    Last Post: 09-15-2010, 05:51 AM
google nexus s doesn't turn on
google nexus s wont turn on
nexus doesn't turn on
nexus s battery not charging
nexus s doesn ?t turn on
nexus s doesn't last long battery
nexus s not turning on
nexus s not turning on or charging
nexus s phone doesn't turn on
nexus s won't turn on
nexus s won`t switch on
nexus s wont power on not charging
samsung nexus doesnt turn on
samsung nexus s doesn't turn on
