Sony Xperia P with no wifi after upgrade to ICS
This is a discussion on Sony Xperia P with no wifi after upgrade to ICS within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi All HELP!!!!! I am in need of some help with a new Sony phone. I bougt this a few weeks back. I had GB ...
Thread: Sony Xperia P with no wifi after upgrade to ICS
    Android Lurker herm1978's Avatar
    Nov 2012
    Hi All
    HELP!!!!!
    I am in need of some help with a new Sony phone. I bougt this a few weeks back. I had GB on the phone so upgraded to ICS but now wifi cant connect to any wifi networks. It can see the wifi but it does not get a ip address fromm any wifi network.
    How can I safely downgrade to GB. Could you also please post the links for the software. Android newbie.
    Thanks in advance.
    Herman
    519 times
    Welcome to the forum Herman. I'm sorry you're having those problems with your phone - unfortunately I'm not the guy that can really help you as I'm a moderator, not a technician. If you can be patient though, some of our more knowledgeable members will be checking in and you should get some help.
    Nov 2012
    Much appreciated, thank you.
  1. Replies: 0
    Last Post: 04-27-2012, 03:43 PM
  2. Replies: 0
    Last Post: 02-21-2012, 12:02 PM
  3. Replies: 3
    Last Post: 06-20-2011, 06:18 AM
  4. Replies: 1
    Last Post: 05-21-2011, 08:00 PM
  5. Replies: 0
    Last Post: 05-21-2011, 07:43 PM
how to downgrade lt29i
no wifi on sony xperia sp after update
problem wifi xperia p on gb
sony xperia p wifi problem
sony xperia wifi upgrading to ics
wifi problem on ics android update xperia
wifi problems in xperia p
xperia p
xperia p ics wifi fix
xperia p ics wifi issue
xperia p ics wifi problem
xperia p problem wifi
xperia p wifi
xperia p wifi probleem
