Media Player/Gallery Problem with Samsung S3
This is a discussion on Media Player/Gallery Problem with Samsung S3 within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi, Been having this problem for quite some time now. I usually upload my photos/music to my s3 by connecting the phone to my com ...
Results 1 to 10 of 10
Thread: Media Player/Gallery Problem with Samsung S3
    Android Lurker tarmade's Avatar
    Jan 2013
    Question Media Player/Gallery Problem with Samsung S3
    Hi,
    Been having this problem for quite some time now. I usually upload my photos/music to my s3 by connecting the phone to my com thru a USB cable, while selecting the optiong "connect as media device". And once i transfer it over, the newly added files will popup in my gallery/music player.
    But recently, files i added did not appear in my gallery. Tried the app Rescan Media but it does not work too. Downloaded a new Music app(Rocket player) and it too is unable to find my newly added music files.
    Suspecting this to be a USB connection issue as the file is in my SDCard but somehow, the media scanner just can't pick it up. The issue might also be caused by me not disconnecting the phone before opening up the gallery/music player.
    So how do i solve this? Last time i solved it by restoring it to factory settings... I totally do not wanna do that again as it is a hassle to back everything up again.
    P.S: I tried the .nomedia solution. There is no .nomedia file in any part of my phone, hidden or otherwise.
    El Paso, TX
    59 times
    _B0BB0_
    Which folder did you move the files to on your phone? Are they visible with a file viewer like Astro?
    Jan 2013
    I move them to my usual music or photo folder which is at root of my SDcard... Its visible from Myfiles...
    El Paso, TX
    59 times
    _B0BB0_
    Have you tried rebooting the phone?
    Jan 2013
    Yup, lots of time actually...
    El Paso, TX
    59 times
    _B0BB0_
    Hmm. Try using an alternative gallery like QuickPik for pics and Power amp for music to force a rescan.
    Jan 2013
    Nope... still cant find them...
    El Paso, TX
    59 times
    _B0BB0_
    Ok last thing then I'm out of ideas, pull the battery and leave it out for about a minute, then put it back in, and reboot it. See if that works.
    Jan 2013
    Hmmm, seems like it works now... Maybe cold rebooting the phone works... Thks alot for your help!
    El Paso, TX
    59 times
    _B0BB0_
    Removing the battery for more than a few seconds resets the memory, so it forces the phone to rescan. Glad it worked!
  1. The XBMC Media Player
    By rain2014 in forum Android Forum
    Last Post: 12-05-2012, 01:54 AM
  2. Media Player for G2
    By josiejo78 in forum HTC G2
    Last Post: 04-23-2012, 09:12 PM
galaxy s3 files does no showed up in gallery and media player
gallery view problems s3
media problem with s3
music player gallery not reading files
s3 music photos problem
s3 music player malfunctioning
s3 music player problems
samsung s3 music file issues
samsung s3 music player priblen
samsung s3 music player problem
samsung s3 videos player problems
samsungs3musicplayer
video not showing when i added .nomedia galaxy s3
video player, gallery can't open samsung galaxy s3
why is my pic on music player on galaxy s3
