Android Phones Won't Work with Bluetooth Earphone
This is a discussion on Android Phones Won't Work with Bluetooth Earphone within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi, some time ago I bought Plantronics M50 bluetooth earpiece and it worked well with nokia e5. Then I changed the phone for android ICS ...
Thread: Android Phones Won't Work with Bluetooth Earphone
    Android Lurker blueadren's Avatar
    Jan 2013
    Hi, some time ago I bought Plantronics M50 bluetooth earpiece and it worked well with nokia e5. Then I changed the phone for android ICS Samsung BT - 5330 and the earphone stopped playing the mp3 ringtone through the earphone and instead it started playing some simple tune. Then I bought another android device (Prestigio PAP3500 DUO) and the same thing went on ie. there was no mp3 ringtone played through earpiece. How to fix this problem, pls help me.
    blueadren
    518 times
    Welcome to the forum!
    Android Sr Member Frederuco's Avatar
    Sep 2011
    /EARTH/USA/NC/
    52 times
    frederuco
    It is probably an issue with the BT profiles supported by your phone.
    About the only fix I can see it to get another phone.
    TransformerForums - Administrator
    AcerTabletForum - NexusTablets - AndroidTablets - Super Moderator
    Android.net - TransformerForums - Rescue Squad
    ASUS Transformer 16GB with Keyboard Dock - Cornerstoned and ICS-ified
    iP*one 4
    Just once I want someone to call me Sir without adding you're making a scene.
    - Homer Jay Simpson
  1. Best Earphone for GN2
    By Rodman1907 in forum Samsung Galaxy Note 2
    Last Post: 11-06-2012, 02:44 AM
  2. Stock Earphone Help
    By turkeysalad in forum Samsung Galaxy S3
    Last Post: 07-26-2012, 03:34 AM
  3. Does this work for Gingerbread phones...?
    By techelec in forum Sony Xperia Play
    Last Post: 09-18-2011, 03:03 PM
  4. This phone does not work with Jabra bluetooth products
    By Clack in forum Samsung Transform Tech
    Last Post: 01-05-2011, 07:41 PM
  5. epic 4g earphone question
    Last Post: 09-25-2010, 10:45 PM
andriod phone won't bluetooth
android can find m50 bluetooth
android paired wont play
can you change the ringtone on a plantronics m50 bluetooth
driod ultra won't pari with jabra hf5001
fix for android bluetooth ringtone galaxy s3
galaxy note ringtone bluetooth headset
how to pair a plantronifcs m50 to an android tablet
pairing plantronics m50 with samsung note 3
plantronics m50 paired but won't connect
plantronics m50 with galaxy note 3
plantronics m50 won't connect to android
plantronics m50 won't pair droid incredible
plantrpnics m50 wont connect
why wont plantronics m50 samsung note 3
