Help
This is a discussion on Help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; OK this might sound weird.. but I accidentely put my phone in the microwave with my food.. but I had to do the laundry so ...
Like Tree2Likes
  • 1 Post By Tears_for_Fears
  • 1 Post By sherri
Thread: Help
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    Help
    OK this might sound weird.. but I accidentely put my phone in the microwave with my food.. but I had to do the laundry so I left it in there.. well when I came back I put on the timer as usual .. about 2 seconds in I heard a sizzle and I immediately stopped the microwave because I could see my phone so I know it wasn't food... well some of the back of my HTC rezound melted.. but my touch buttons or the bottom of the screen works anymore..the problem is I can't take it back because its rooted, any help is appreciated
    Motorola Droid RAZR MAXX - Droid X2
    Android Lurker jckatz's Avatar
    Dec 2012
    Re: Help
    Even a rooted phone can be reset to Factory settings. Just back everything up. And do a hard reset.
    Apr 2012
    230 times
    Re: Help
    Quote Originally Posted by cd_fifty_6 View Post
    You mean the capacitive buttons and the bottom of the screen don't work anymore?
    You can wipe all the changes you've made, then unroot the phone. But that won't do any good, since the warranty doesn't cover physical damage.
    My question, why on Earth did you put your phone inside the microwave? It's one thing to forget, but what made you put it inside in the first place?
    UltraDroid likes this.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    7 times
    @milkmac9
    Re: Help
    I really have no freaking clue
    Android Enthusiast sherri's Avatar
    16 times
    Re: Help
    OK. I may be drunk, but what in the world would rooting have to do with this? Rooting voids manufacturer warranty. So....if you root phone and speaker no longer works, you can't get it replaced under warranty. I this case, unrooting and resetting will help. (Makes it look like a hardware failure....)
    However, nuking your phone (or washing it, bathing it, dropping it from a bridge, using it for a toboggan, running it over, seeing if it will sink or float, using it as a Frisbee, or any other such crap...) is clearly NOT a manufacturer defect. May be covered (it is by Asurion, with a deductible....) on an outside warranty, but then they won't care if phone is rooted or not. I have TEC care through Verizon (extends manufacturer warranty....) so when my daughters unrooted Droid 2 stopped making sounds, it was covered, although phone is 3 years old. If her phone was rooted, thus was STILL covered, as it was a manufacturer defect (and phone could be unrooted). If she used the phone to play ice hockey with, and phone broke, rooted it not, this is not a manufacturer defect. TEC wouldn't cover it, even if phone was brand new.
    Asurion will cover that, but with the deductible, which is $100.00......
    Sent from my XT912 using Tapatalk 2
put rooted android in microwave
rezound asurion
rooted phone physical defect
