Survivor Case for SAMSUNG Galaxy Note2 Review
This is a discussion on Survivor Case for SAMSUNG Galaxy Note2 Review within the Samsung Android Phones forums, part of the Android Phones by Model category; This Survivor case for Note 2 is designed from the inside out to protect your Samsung Galaxy Note 2 from extreme conditions and a host ...
Thread: Survivor Case for SAMSUNG Galaxy Note2 Review
    Banned fingg's Avatar
    Mar 2013
    This Survivor case for Note 2 is designed from the inside out to protect your Samsung Galaxy Note 2 from extreme conditions and a host of other environmental factors. First release for ipad mini, now is new released for SAMSUNG Galaxy Note 2.
    This survivor case for Galaxy Note 2 is designed from the inside out to protect your Note 2 from extreme conditions ... dirt, sand, rain, shock, vibration and a host of other environmental factors.
    It has been designed to meet or exceed the durability standards set by the US Department of Defense. It also meets the standards of the Ministry of Defense in the UK. This Galaxy Note 2 survivor case is extremely sturdy and made up from a shatter- and shock-resistant polycarbonate.
    This Note2 Survivor case is built on a shatter-resistant polycarbonate frame clad in rugged, shock absorbing silicone.
    A built-in screen protector seals your Multi-Touch display from the outside environment, while hinged plugs seal the dock connector, camera lens, headphone port, hold switch and volume controls.
    So you can freely convert video to note2 to computer easily with Dock Connector to USB Cable Line.
    The included stand clips on, then folds open for landscape viewing and typing.
    Some Specializations:
    - Independently tested to meet conditions outlined in US Department of Defense MIL-STD-810 and UK Department of Defense Def-Stan 00-35
    - Integral Display shield deflects wind and rain (Test: up to 200 mm/hr for 1 hour)
    - Rigid internal frame protects against shocks and drops (Test: drop on flat concrete surface from 6'/1.8 m)
    - Sealed ports block blown sand and dust (Test: up to 18 m/sec for 1 hour)
    - Silicone cladding blocks vibration (Test: 18 hrs at 20 to 2000 Hz)
    - Multi-position clip attaches securely to pack strap or belt
    Mar 2013
    Just the release new camouflage note2 case is cool
    Name:  Survivor Case for SAMSUNG Galaxy Note2 cam2.jpg
  1. Replies: 0
    Last Post: 10-01-2013, 11:42 AM
  2. Replies: 0
    Last Post: 06-08-2013, 09:54 AM
  3. Samsung Epic 4G Case Review Thread
    By danDroid in forum Samsung Epic 4G Accessories
    Last Post: 10-29-2010, 12:07 AM
  4. Review: Case-Mate Tough Case
    By wildrage in forum Nexus One Accessories
    Last Post: 04-12-2010, 03:27 PM
galaxy note 2 case cool
galaxy note 2 survivor case
galaxy note 2 survivor case review
note 1 survivor case
note 2 survivor review
samsung galaxy note 2 survivor case
samsung galaxy s4 cool cases
samsung note 2 survivor case
samsung s4 sturdy, rugged case
survivor case for galaxy note 2
survivor case for note 2
survivor case galaxy note 2
survivor case note 2
survivor cases for galaxy note 2
