Samsung Captivate Replacement Battery
This is a discussion on Samsung Captivate Replacement Battery within the Samsung Captivate Accessories forums, part of the Samsung Captivate category; I bought a secondary battery on amazon for my Galaxy S cell phone. It works as long as the original battery. I bought it because ...
Thread: Samsung Captivate Replacement Battery
    Junior Member Asclepius's Avatar
    I bought it because I had to charge my cell phone twice a day.
    Now I use a AC Clip Charger to charge the second battery.
    now I can just bring the battery with me and swap it out.
    Works out well for me.
    Here is the battery I bought off Amazon Amazon.com: RND Power Solutions' Premium Standard Lithium-Ion Battery (EB575152VA) for Samsung Captivate i897, Vibrant T959, Epic 4G, and Fascinate: Electronics
    I recommend buying a second battery easier to swap out then being held hostage to a charger.
    Android Lurker MicroBeta's Avatar
    Norwich, CT
    I've often thought about doing this.
    How do you carry around the extra battery? Do you have a case or bag to protect the contacts?
    Mike
    Battery Storage
    I use an anti static bag to protect from moisture, dirt, and any other external elements that can damage the battery.
    I would recommend if you can find the right size plastic battery holder case to use that.
    Member kschumake83's Avatar
    I have noticed that when swapping batteries a lot I would have to delete my battery stats atleast once a week or my battery life would go to hell and 2 batteries would only last as long as one. So yesterday I received my extended battery from Amazon and I'll report back in a couple of days to let you know how it goes.
buy samsung captivate battery
captivate battery replacement
new battery for samsung captivate
new samsung captivate battery
replace battery for samsung galaxy captivate
replacement battery for captivate
replacement battery for samsung captivate
replacement battery samsung captivate
samsung captivate battery replacement
samsung captivate new battery
samsung captivate replacement battery
samsung galaxy captivate battery replacement
samsung galaxy s captivate battery replacement
when should i replace my samsung captivate battery
