Why this cable doesn't work?
This is a discussion on Why this cable doesn't work? within the Samsung Captivate Accessories forums, part of the Samsung Captivate category; Hello all, This is my first post on this forum but I 've been followin us... I have a Captivate and I worried because I ...
Thread: Why this cable doesn't work?
    Junior Member vaickiballs's Avatar
    Apr 2011
    Hello all,
    I have a Captivate and I worried because I haven't get to plug it on my TV, I thought that it needs a special RCA cable because I tried with all my RCA cables and didn't work...so i bought one from here but I discovered that it doesn't work neither....
    So the question is....It is the wrong cable or it is my phone broken?
    Thank you very much
    PD: i've select the correct external channel on TV and changed the settings on the phone tv-out etc...
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Sorry I didn't see this before, but are you running a custom ROM? If so, is it an i9000 base ROM? The i9000 ROM's are known for not supporting NTSC out through the headphone jack. Since the International spec GT-i9000 isn't offered in the US, it's restricted to PAL video output that none of the TV's sold in the US will recognize.
    Apr 2011
    Thank you for your answer!
    I've got de official version 2.2 of captivate and I need to use with the PAL mode...
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Ahh... so you actually want to use PAL. Well, the i9000 kernels out for the captivate might have been reoriented to use NTSC. Are you certain you're using a compatible cable? Some 3.5 RCA adapter cables don't work... I can't remember if it's the Nokia style or the Apple style that works. I believe its the Nokia style.
    The reason some cables don't work is because the jack connectors are wired differently with different OEM's.
    Sent from my SGH-I897 using Tapatalk
    Apr 2011
    Yes i want to use PAL, i've bought the original rca cable and also tried the nokia rca....may be the the problem is the kernel... Any idea avout which one could make it work?
    Thank you for your help!
cable doesn't work with samsung tv
cable doesnt work on samsung tv
captivate tv out
captivate tv out cable
i9000 tv out not working
no video on samsung 850 with rca cable
rca cable for 19000
rca cable for samsung phone doesn't work
samsung cable doesnt work
samsung captivate rca tv out cable
samsung captivate tv out doesn't work
samsung captivate tv out not working
samsung tsblet rca cwble doesnt work
samsung video out cable doesn't work
why cable doesn't work on samsung
