Avoid Data plan by using Samsung Captivate
This is a discussion on Avoid Data plan by using Samsung Captivate within the Samsung Captivate FAQ forums, part of the Samsung Captivate category; :confused: haha I had a 2GB data plan w/ AT&T until I realized I don't need nearly that much.I have always had great WiFi connection ...
Results 11 to 12 of 12
Thread: Avoid Data plan by using Samsung Captivate
    Android Lurker peteski72's Avatar
    Dec 2011
    :confused: haha I had a 2GB data plan w/ AT&T until I realized I don't need nearly that much.I have always had great WiFi connection at home. (no need to have data for web service) I recently lower my data plan to 300 MB. Now I cannot get WiFi connection at home. It immediately connects to 3G racking up data usage. Is this some weird trick they can do?
    Dec 2011
    Help Data usage on ATT
    I will try your directions and close my current wifi on my phone and reset it. I really hope this works. AT&T had me do a hard reset and then after that said I was due for an upgrade. They suggested I get a new phone w/ a new 2 year contract. I don't know if I want to because I don't have a clue which phone to pick. There's to many choices.I have a Samsung Captivate. It's OK,but not great. They were so slow coming out with newer updates. I need a phone that is easy easy texting. i.e. key board, big screen. To get into a good phone with an upgrade will still cost $199.00 Ouch! Any ideas?:mad:
at&t samsung captivate without data plan
can you use a samsung captivate without a data plan
does the samsung captivate glide need a data plan
does the samsung captivate glide require a data plan
does the samsung captivate require a data plan
how to turn data off on samsung captivate glide
how to turn off data on samsung captivate glide
how to turn off internet on samsung captivate glide
how to use samsung captivate without data plan
samsung captivate glide how to turn off data
samsung captivate glide no data plan
samsung captivate glide turn off data
samsung captivate no data plan
