i have busybox, the phone rooted, and sqlite installed
i open cmd prompt as admin, and get to it
cd to SDK install directory
cd tools
adb shell
su
cp /dbdata/databases/com.android.providers.settings/settings.db /sdcard/settings.db
cp /dbdata/databases/com.android.providers.settings/settings.db /sdcard/settings.db.backup
exit
exit
(This should bring you back to your windows command prompt.)
adb pull /sdcard/settings.db %userprofile%\desktop
(This should copy the settings.db to your desktop in Windows. Keep your cmd window open, you'll need it again.)
it doesnt appear to do anything, alot of text comes up after the pull command, but then when i look for settings.db with SQLite i find nothing............help!
