Killing/Changing boot sound
This is a discussion on Killing/Changing boot sound within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; Any thoughts on how?...
Thread: Killing/Changing boot sound
    Junior Member rahlquist's Avatar
    Senior Member jmgib's Avatar
    Kentucky
    There doesn't appear to be a setting for it. Not possible to change it as far as I know.
    Well frack my sound level at boot it horrid despite anything I try to do.
    /system/etc/PowerOn.wav
    /system/media/bootsamsung.qmg
    /system/media/bootsamsungloop.qmg
    I renamed those 3 files and thats all it took, killed the two boot animations and sounds.
    Kentucky
    Congrats. Glad you found what you were looking for. Actually I misread the forum you posted this in and I was thinking of the Backflip.
    Member watatek's Avatar
    Quote Originally Posted by rahlquist View Post
    Could anyone post the PowerOn.wav file please.
    After the Rom update it seemed to disappear.
    I kinda like the short animation/sound.
    Thanks!!
    Junior Member hurstrescue's Avatar
    If you want to remove the power off sound:
    system/media/audio/ui/shutdown.ogg
  1. saving apps to sd card
    Last Post: 12-21-2010, 12:07 PM
  2. Samsung Epic 4g coming August 11th?
    Last Post: 08-05-2010, 03:09 PM
android boot audio
android boot sound
boot animation galaxy proclaim
change android boot sound
change boot sound android
download glide bootsamsungloop.qmg
how to change boot sound android
how to change boot sound on android
how to change the sounds on a samsung captivate
how to turn off startup sound on galaxy proclaim
proclaim boot sound
samsung boot sound
samsung captivate shutdown.qmg
samsung captivate startup sound
shutdown qmg versi transformer
