problems with android market after rooting my captivate
This is a discussion on problems with android market after rooting my captivate within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; hi. i am new to the android scene. i have just recently rooted my samsung captivate using the app from the market called one click ...
Thread: problems with android market after rooting my captivate
    Junior Member anarchy_now's Avatar
    hi. i am new to the android scene. i have just recently rooted my samsung captivate using the app from the market called one click lag fix. i then downloaded the titanium backup app and used it to remove most of the at&t bloatware on my phone. i got back on the market later tonight and was trying to explore the new world of root-only apps and noticed that i couldnt download anything from the market. i did some research and decided the google talk apps i uninstalled were the cause of this problem. i tried to reinstall them with titanium backup but could not get it to work. what should i do?
    Junior Member j101399j's Avatar
    Use the one click back to stock flash here: [STOCK ROM] Odin3 One-Click Downloader and Drivers - xda-developers
    This will take you back to stock and undo everything you did
    Then root the device again
  1. Epic 4G Car Mount - Arkon Mega Grip Holder
    Last Post: 08-04-2010, 05:49 PM
after rooting my android i have problems
android market not working after root
android market problems after rooting
how to use android market after rooting
market app problem after rooting
problems downloading apps on android market- samsung captivate
samsung captivate market not loading
