RyanZA's One Click Lag Fix easiest way to root samsung captivate
This is a discussion on RyanZA's One Click Lag Fix easiest way to root samsung captivate within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; I was trying to root my sisters phone and gave up last night, my computer was being retarded and i was having to use tether ...
Results 1 to 8 of 8
Thread: RyanZA's One Click Lag Fix easiest way to root samsung captivate
    Member wikidcerealkilla_attdroids's Avatar
    I was trying to root my sisters phone and gave up last night, my computer was being retarded and i was having to use tether from my aria, wasnt fun. So i remember seeing some apps on the galaxy from the market about lag fix... so i downloaded RyanZA's One Click Lag Fix. It had a root me button. It actually installed the update the proper way and asked to reboot it and install... can it be too easy, superuser permission. I added rom manager and approvrd superuser.
    Can it be more easy...
    An app for it?
    HTC Aria Cyanogen 6 overclocked to 845mhz using Tapatalk Pro
    HTC Aria... rooted
    Clockwork recovery
    CYANOGEN 7 Gingerbread
    Overclocked to 805 MHz
    Former phones...
    HTC G1... that I have since rooted and gave to brother.
    Motorola Backflip... many calls and replacements till they gave me the Aria
    IPhone 3g... enough said
    Junior Member flyerfan25's Avatar
    That does sound too easy, even for us smartphone noobs.... if anyone has more info about this easy root feature, please post.
    You can always check it out here...
    http://www.appbrain.com/app/com.rc.QuickFixLagFix
    Or search the market for ryanza oclf
    HTC Aria Cyanogen 6 nightly (9/24/10) using Tapatalk Pro
    HTC Aria... rooted
    Clockwork recovery
    Former phones...
    Also... you still need to download rom manager to give you recovery
    HTC Aria... rooted
    Clockwork recovery
    Former phones...
    ROM Manager... downloaded the RyanZA app, didn't note that.. seemed as easy as 1,2,3... am I missing something here before I actually go ahead and run that app to root phone and run the tools...
    No... thats why i was so shocked... i was talkibg to jasonyump about it to make sure it was a legit root and he said "yeah, that easy" basically it installs superuser and after reboot you just have to flash recovery
    HTC Aria... rooted
    Clockwork recovery
    Former phones...
    Umm. OK I know what flash memory is but not sure what you specifically mean on this statement. After the app does it's thing and reboot, what specifically am I supposed to do outside of what the app state in downloading the tools. "you just have to flash recovery"
    download ROM Manager from the app market and it will install clockwork recovery, the recovery replaces the stock recover so tou can install custom roms. Well when one is ported. But you can remove at&ts apps and sideload apps, install apps not in the market
    HTC Aria... rooted
    Clockwork recovery
    Former phones...
one click lag fix
one click lag fix apk download
one click lag fix captivate
one click lag fix download
one click lag fix download from android market
one click lag fix from android market
one click lag fix root
ryan za
ryanza
ryanza one click root
ryanza's one click lag
ryanza's one click lag fix
ryanza's one click lag fix apk download
ryanza's one click lag fix download
ryanza's one lag fix
