Need Help!!
This is a discussion on Need Help!! within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; First thing: In my music app in th recently added list it shows all my songs since i flashed my first rom and not what ...
Results 1 to 8 of 8
Thread: Need Help!!
    Member Udecide's Avatar
    Need Help!!
    First thing:
    In my music app in th recently added list it shows all my songs since i flashed my first rom and not what is new ..... that would be okay as long as it was in the order added and not alphabetical!!!! it is really annoying when i'm looking for the new tunes i just downloaded ( i forget the names alot)
    Second thing:
    How can i get my phone overclocked... is it good to overclock a captivate.... i underclock it now with set cpu to help extend battery and that works decent!!
    Hello?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    First thing in unavoidable.
    Second, you have to flash an OC/UV kernel.
    Could you explain the oc kernel thing a little more
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    If XDA weren't down I'd link you to a kernel you could flash from there... All you have to do is flash the kernel from recovery to gain OC/UV abilities. The kernel I use isn't OC/UV compatible, but it's been highly optimized by the developer to be as fast as possible at 1GHz... but still have good battery life.
    what kernel?
    i want a really good battery saver
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Battery saver and OC/UV don't really go well together. OC'ing will give you bad battery life. UV'ing will give you better battery life, but will most of the time make your device prone to freeze and crash.
    Of the OC/UV kernels, this is the one I recommend... Here.
    Get the 1.5.6xt CWM version, then flash it from recovery. Voltage Control will be able to control the over-clocking and under-volting.
    Over clocking makes SENSE! BUT WHAT IS under volting
datpiff app
