Not able to use speed dial process stops unexpextedly after going to 2.2
This is a discussion on Not able to use speed dial process stops unexpextedly after going to 2.2 within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; Hello I was wondering if anyone else has this issues after flashing to 2.2 using UGJK3. Everything else is GREAT not complaining at all just ...
Thread: Not able to use speed dial process stops unexpextedly after going to 2.2
    Member tonyzz's Avatar
    Hello
    I was wondering if anyone else has this issues after flashing to 2.2 using UGJK3. Everything else is GREAT not complaining at all just didn't know if it was a bug
    error is: The process android.process.acore has stoppped unexpectedly Please try again and then force close. Closed a few times and even rebooted but same error.
    Thank you Doran for your great install directions, worked perfectly, I also found my 3g speeds are much faster after the flash.
    Tony
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Yea, it's a bug, but I'm not sure why it's doing it. I'll play around with speed dial and look at the logcats from the crashes and see if I can figure it out.
    Thank you Dorian, and thanks again for providing different versions. your 2.2 is running great on my captivate, ready to flash my friends sometime this week
  1. Is Samsung goiung to fix bluetooth???
    Last Post: 09-19-2010, 03:07 PM
galaxy s2 speed dial not working
samsung captivate dial *
samsung galaxy s2 error when speed dial
samsung galaxy s2 speed dial not working
samsung galaxy s2 speed dial problem
samsung galaxy speed dial android.process.acore error
samsung galaxy speed dial android.process.acore fix error
samsung galaxy speed dial error
speed dial error galaxy s2
speed dial not working in sgs2
speed dialing not working on samsung galaxy s2
speed doal error with galaxy s2
