I do not have "unknown applications" setting after updating to FROYO
This is a discussion on I do not have "unknown applications" setting after updating to FROYO within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; Got phone, did the mini keis update to firmware 2.2 Froyo and I still have no " unknown applications" menu under Applications. How ca I ...
Thread: I do not have "unknown applications" setting after updating to FROYO
    Android Lurker androidtigger's Avatar
    Post I do not have "unknown applications" setting after updating to FROYO
    Got phone, did the mini keis update to firmware 2.2 Froyo and I still have no " unknown applications" menu under Applications. How ca I get this function or am I needing to root first? I am totally new to Android system so any help or step by step would be appreciated.
    :confused:
    Senior Member nakedninja42's Avatar
    If you are running stock froyo then there is no Unknown Applications setting, that is only in the I9000 ROMS.
    Check out this link to root and enable side loading
    [APP]SuperOneClick v1.9.1 (Root, Unroot, Enable Non-Market App) - xda-developers
    Senior Member jmgib's Avatar
    Kentucky
    ATT has removed this feature from the ATT branded firmware.
    thanks
    Thanks for the help. Super1click worked with no issues. chose allow 3rd party applications, voila!. Now all I need to do if figure out what AT&T BS to throw away!.
    Quote Originally Posted by androidtigger View Post
    If you don't already have it installed, check out Titanium Backup to remove the bloatware.
    I was going to originally post this link to enable side loading
    http://www.attdroids.com/forum/samsu...y-trace-t.html
    but remembered froyo has 3e recover so rooting and side loading would have been different. Check out the rest of the article to remove the bloat
    Senior Member Johnnie5000's Avatar
    Chattanooga
    All of it.
    Samsung SGH-I897 [Build 1007] - teamhacksung's ICS {Android 4.0.1}
    Asus TF101 [Build B70] - Revolver 3.9.5 {Android 3.2.1}
    HP Touchpad {WebOS 3.0.2 + CM 7.1 Alpha 3}
    Cool Agreed
    I totally agree. I am just happy that I "made" it happen with no issues. ( not the story usually) Thanks again for the help and ideas!
application not installed samsung i897
download apps for samsung sgh-i897
how to install non market apps on samsung sgh-i897
how to install unknown application on samsung galaxy i987 at&t
howvto allow non market app on samsung 1897
i have sumsung at&t model sgh i897 but there is no un nown resouces
install unknown sources on sgh - i897 running 2.2
samsung i897 sideload apps
samsung sgh 1897 how to install non market
samsung sgh i897 unknown sources
samsung sgh-i897 unknown market settings
sgh i897 sideload apps
unblock installations of unknown sources on sgh 1897
where to locate samsung galaxy s sgh-i897 unknown. source
