ATT Captivate Phone Frozen up ......... Please help
This is a discussion on ATT Captivate Phone Frozen up ......... Please help within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; I (have) had a rooted Samsung Captivate Phone. Phone was fine that was months ago. Today I was trying to change the permissions to sideload ...
Thread: ATT Captivate Phone Frozen up ......... Please help
    Junior Member puttingg's Avatar
    Today I was trying to change the permissions to sideload an app and might have move the enabled SD file somewhere other than where it was suppose to go. A red SD came up top saying the SD was almost full. (i think that was the warning. The phone was working (calling) and apps appeared to be working fine. The phone was acting funny so I removed the battery and and SD card and then put them back in. The phone would start but nothing never boot up. Just a black screen. So I held the volume and power button to get to the recovery mode.
    update media, please wait .....
    update media, finished
    # MANUAL MODE #
    ---- Applying Multi-CSC .......
    Installing Multi-CSC
    It appears to be frozen here .......... I have these options up top
    reboot systems now (did this and still didn't fix the issue)
    reinstall packages (did this and still didn't fix the issue)
    delete all user data (did not do this)
    delete cache data (did not do this)
    Any help is much appreciated ......... very concerned I just bricked my phone ................
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Just pull the battery. Or does it boot to the recovery screen by just pressing the power button?
    Senior Member Johnnie5000's Avatar
    Chattanooga
    If it still turns on, it's not bricked. Soft-bricked maybe, but totally fixable. You can always flash back to stock 2.1 with Odin 1-Click via download mode and re-install apps/re-root from there. Important thing is chill out, don't panic and read this How to unbrick the totally bricked Captivate - xda-developers.
    Samsung SGH-I897 [Build 1007] - teamhacksung's ICS {Android 4.0.1}
    Asus TF101 [Build B70] - Revolver 3.9.5 {Android 3.2.1}
    HP Touchpad {WebOS 3.0.2 + CM 7.1 Alpha 3}
how to fix a frozen screen of samsung sgh-i897?
i897 black screen
my samsung captivate is frozen
samsung captivate black screen
samsung captivate black screen fix
samsung captivate frozen
samsung captivate frozen at&t screen
samsung captivate frozen screen
samsung captivate i897 black screen
samsung captivate screen freezing at start up
samsung i897 bricked
samsung i897 captivate black screen
samsung sgh-i897 black screen
samsung sgh-i897 bricked
