In need of 1 on 1 help, Rooting my Captivate
This is a discussion on In need of 1 on 1 help, Rooting my Captivate within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; Im having trouble Rooting my Captivate because im running the official 2.2 Im New at all this stuff, and after browsing a bunch of forums ...
Thread: In need of 1 on 1 help, Rooting my Captivate
    Junior Member risingwolfe's Avatar
    Jun 2011
    Im New at all this stuff, and after browsing a bunch of forums and threads i figured that i need one on one help, or a step by step explanation that Defines Everything. Any Help would be appreciated.
    Junior Member PabloCR's Avatar
    Do not over think.
    This is the deal with official 2.2 rooting should not be a problem but recovery on that build is locked to run ONLY signed updates, that means even with a rooted phone you won't be able to install clockwork of flash anything else.
    You need to flash the old recovery to be able to move forward, the easiest way is to look for the ODIN one click ECLAIR for captivate. A little search on XDA or google will lead you straight to it.
    Dorian's also sugest using KF1 one click to instal his JVP 2.0 I haven't done it tis way but Dorian is an excellent developer and he knows what he's doing so you can fully trust him on that.
    Just in case you are wondering KF1 was the official release of gingerbread for the captivate, most of the other roms are based on the i9000 GB rooms.
    Good Luck!
    Senior Member Johnnie5000's Avatar
    Chattanooga
    If you're on the official craptacular AT&T version of 2.2 all you need is: [APP]SuperOneClick v2.0 (MORE ROOTING!) - xda-developers Instructions are in the link, but since you need extra help:
    Download the SuperOneClickv2.0b1-ShortFuse.zip file.
    Run SuperOneClick.exe.
    Make sure your phone is set for USB Debugging mode [Menu soft key -> Settings -> Applications -> Development -> USB Development -> USB Debugging]
    Connect your usb cable to your phone.
    Wait about 15-20 seconds.
    Click on Root.
    Profit.
    Samsung SGH-I897 [Build 1007] - teamhacksung's ICS {Android 4.0.1}
    Asus TF101 [Build B70] - Revolver 3.9.5 {Android 3.2.1}
    HP Touchpad {WebOS 3.0.2 + CM 7.1 Alpha 3}
    Android Lurker arnele's Avatar
    Apr 2011
    i installed the SuperOneClickv2.0b1-ShortFuse.zip file on my laptop. when I opened it, it advised that I must flash an insecure kernal to my device before running this software. How do I do that? I hav a Samsung Captivate i897 (2.2). I also installed super one click (other) and when i try to run that with usb cable connected (usb debugging and allow mock locations turned on), it says signature verification failed- installation aborted. It mentioned somewhere that to be able to run super one click for 2.2 I would first need to install a 3e fix. The link for the 3e fix was 404 (not found). I also could not find any working link for a 3e fix download on google.
    Apr 2011
    can anyone help me?
    Apr 2011
    when i tried to run super one click short fuse, it said required file missing
3e recovory no sig check i897
e signature verification failed in i897
how to root captivate 2.2
how to root samsung captivate 2.2
how to root samsung-sgh-i897,2.2
i897 signature verification failed
my samsung sgh i897 is rooted how do i install clockwork recovery
root captivate 2.2
root captivate 2.2 esignature failed
root samsung captivate i897 2.2
samsung i897 rooting problem
sgh-i897 2.2 signature verification fail fix
signature verification failed i897
step by step how to root my samsung captivate
why super one click want root my samsung i897 captivate
