Froyo upgrade to Gingebeard HELP
This is a discussion on Froyo upgrade to Gingebeard HELP within the Samsung Captivate Hacking forums, part of the Samsung Captivate category; My phone original spec- Samsung Captivate: - stock Android 2.1 - factory pre-installed - Current status: Froyo 2.2 I897UCJI6 with rooted and carrier unlocked. Now ...
Thread: Froyo upgrade to Gingebeard HELP
    Junior Member laoban's Avatar
    Oct 2011
    Now I am thinking to upgrade my existing rooted and unlocked Froyo 2.2 to Gingerbeard 2.3.5 I897UCKJ3 ATT firmware.
    My question is what is the correct procedure to perform the firmware upgrade? Should I downgrade to stock 2.1 first before upgrade to 2.3.5 OR I can simply run odin to upgrade to 2.3.5 directly, followed by rooting and unlocking.
    Can anyone who has the experience with the 2.3.5 firmware upgrade clarify for me step-by-step how to do this. Thanks in millions.
    Thanks.
    Member Dawn's Avatar
    Sep 2011
    you can upgrade to 2.3.5 and get root back with designgears-autoroot kernal from UFKC1 or what ever you would flash that kernel in download mode and then have root or u can flash dorians rom and get better speeds with internet
2.3 froyo rooted for captivate
flash firware 2.2 froyo to 2.3 captivate
gingebeard
samsung captivate 2.2 froyo update 2.3.5
upgrade from android 2.2 to 2.3
