Quote Originally Posted by moosefist View Post
If you want a wifi hotspot feature, I believe we are going to have to a custom kernel (unless for some reason ours already includes support for IPtables)
You can tether through bluetooth with PDAnet though. Honestly unless you need to share the connection I always find it best to use the data cable if possible. The bluetooth and wifi tethering on other phones creates a massive battery drain.
android-wifi-tether is now somewhat working. Ad-Hoc only, and no dhcpd, but it works!
2.0.5-pre4 works for me.
First time you run it, your Cappy will lock up hard, just remove and reinsert battery, and should be OK.
T
