How to setup Wireless Tethering?
This is a discussion on How to setup Wireless Tethering? within the Samsung Captivate Tech forums, part of the Samsung Captivate category; Has anyone been successful setting up Wireless Tethering on the Captivate?...
Results 1 to 10 of 11
Thread: How to setup Wireless Tethering?
    dandroid
    Guest dandroid's Avatar
    Member sparky's Avatar
    Red Dirt Of Oklahoma
    Dan i have PDA net loaded it works good on usb i will try bluetooth and report back
    Junior Member Yzlvr's Avatar
    Are you tethering to windows? 7 or XP? I tried and the USB Modem drivers will not load correctly in 7. I think they are for XP and vista.
    Also does anyone know how to set up a mac to use the usb tethering?
    Senior Member jmgib's Avatar
    Kentucky
    Vista drivers should work in Windows 7. Windows 7 is basically just Vista 2nd Edition with a nicer UI.
    I can't get the driver to install in 7. Not sure what I am doing wrong.
    Kentucky
    What kind of error are you getting? Are you running a 32-bit or 64-bit version of Windows?
    this device cannot start code 10. when installing driver.
    debugging off and choose pc internet.
    64 bit, also tried on 32 bit 7 on mac. no go, same error.
    Just got it working. Found drivers here. http://zedomax.com/blog/2010/07/14/s...iver-download/
    If I could only get it to work on my mac now I would be set... Anyone?
    I think is you go to sansungs web sight you will find driver downloads i got mine for windows 7 there
    Moderator moosefist's Avatar
    If you want a wifi hotspot feature, I believe we are going to have to a custom kernel (unless for some reason ours already includes support for IPtables)
    You can tether through bluetooth with PDAnet though. Honestly unless you need to share the connection I always find it best to use the data cable if possible. The bluetooth and wifi tethering on other phones creates a massive battery drain.
  1. Keyboard Question
    Last Post: 09-02-2010, 08:59 PM
android wireless tether how to configure
how to configure wireless tether
how to set up tethering on samsung captivate
how to set up tethering on windows 7
how to set up wireless tether
how to set up wireless tethering
how to wireless setting samsung android
samsung captivate bluetooth tethering
samsung captivate tethering
samsung captivate wireless tether
samsung captivate wireless tethering
samsung tethering setup
setting up samsung phones for tethering
setting up tethering on a samsung captivate
windows 7 wireless tether
