Problem connecting to computer/Kies?
This is a discussion on Problem connecting to computer/Kies? within the Samsung Captivate Tech forums, part of the Samsung Captivate category; My phones almost a week old. First off, it took a while for me to successfully install the proper drivers and Kies for the phone. ...
Thread: Problem connecting to computer/Kies?
    Junior Member shmedley's Avatar
    My phones almost a week old. First off, it took a while for me to successfully install the proper drivers and Kies for the phone. Second off, it would have been nice if i was told to download Kies instead of having to search the internet to find this out.
    but, my problem is that i was only able to connect it 1 time. it took a while for me to figure it out, but eventually i had to restart my computer, and restart the phone by taking the battery out. Now when i try to connect, the phone shows that its connected, but the phone never shows up in Kies. I've restarted the phone a couple of times, but still no luck.
    Is there a quick fix to this, or do you think theres something defective with the phone? I know its not my computer because my USB's all work fine for other devices.
    Thanks....i love the phone, but just wish it was easier to add/delete music and videos. its getting really frustrating because my external memory card is completely empty right now and theres plenty of stuff i want to put on it.
    Junior Member Windycity's Avatar
    It could be your USB connectivity settings. Try changing the default to "Ask whenever you connect." You should have chosen "Kies" as your connection once you plug it in, if you want to use it with Kies. Hope this help.
    Junior Member tempusfugis's Avatar
    Quote Originally Posted by shmedley View Post
    What OS are u running? I have Win 7 x64 and it is flaky there at best. I've come up with a work-around of sorts: On your phone, go to settings>Applications>USB Settings and choose Samsung Kies (this way there's no prompt when connecting your phone via USB). Now, since you already installed kies, connect the phone and it should auto-launch the application. If it does not, you can either manually launch it or (my choice) just wait for the auto play options window to come up...then you can just open the phone's folder and browse both internal and external (sd card) memory. I like this better 'cause you can just drag and drop media and it will still be catalogued by the phone.
android kies download for pc problems
captivate not connecting to kies
galaxy s4 shows connecting when trying to connect to kies
how to connect my samsung captivate to kies mac
how to connect samsung captivate to kies
i9210t not connecting kies
keis i927 connection trouble
kies shows connecting but never does
problem connect to samsung kies
samsung captivate kies not connecting
samsung captivate not connecting to kies
samsung captivate not connecting to pc
samsung kies not connecting to captivate
samsung kies you are not connected to the internet
you are not connected to the internet kies
