No Sound from Phone's speakers, but sound from earphones?
This is a discussion on No Sound from Phone's speakers, but sound from earphones? within the Samsung Captivate Tech forums, part of the Samsung Captivate category; I own a Samsung Captivate, I've been having problems with its sound. I noticed no sounds work from my phone's speakers. The only sounds I ...
Thread: No Sound from Phone's speakers, but sound from earphones?
    Junior Member lalaworld123's Avatar
    I own a Samsung Captivate, I've been having problems with its sound. I noticed no sounds work from my phone's speakers. The only sounds I could hear are from my earphones. This my 3rd Samsung Captivate in the last 11 days. (I don't know why all the possible problems that can occur on this phone occured to mine, consecutively -.-) I've tried to "tap" down on the speakers, like I've read from other Droid Forums, but that doesn't seem to help at all. I've tried to reset and uninstall all my applications. Does anyone have a solution to this, I'm tired of going back and forth to the AT&T store. :mad:
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Sounds like the headphone jack is bad. When you plug in headphones, it has a contact that tells it headphones are plugged in, but when you unplug them it senses that and reroutes audio to the speaker.
  1. Galaxy s power pack...
    Last Post: 10-28-2010, 12:08 PM
  2. Samsung Epic 4g coming August 11th?
    Last Post: 08-05-2010, 03:09 PM
captivate no sound
captivate sound problem
motorola backflip no sound
no sound on captivate
no sound on samsung phone
no sound samsung captivate
samsung captivate audio problems
samsung captivate no sound
samsung captivate no sound except in headphones
samsung captivate no sound speaker
samsung captivate sound issue
samsung captivate sound issues
samsung captivate sound problem
samsung fascinate no sound
the sound on my phone only works with headphones
