HELP using FULL ODIN3 program instead of ODIN3 1 click
This is a discussion on HELP using FULL ODIN3 program instead of ODIN3 1 click within the Samsung Captivate Tech forums, part of the Samsung Captivate category; I just managed to pull my fully bricked captivate out of the darkness and FINALLY have the "Downloading" screen on my captivate. ODIN3 1 click ...
Thread: HELP using FULL ODIN3 program instead of ODIN3 1 click
    Junior Member Yahoo! Serious's Avatar
    ODIN3 1 click does not give me a yellow com port (does not connect)
    But
    The FULL ODIN3 program does have a yellow com port.
    the trouble is I dont know where to find..much less WHAT to look for to fill in
    the odin3 full.
    everyone here in the USA seems to use the ODIN3 1 click and not full odin.
    I need help finding:
    SELECT OPS:
    SELECT IMAGE TO DOWNLOAD (BOOT)
    (PHONE)
    (PDA)
    (CSC)
    Select integrate package (ONE PACKAGE)
    and what checkboxes to check to get the phone back to a working state.
    thank you very much!!
    Y!S
    oKAY after I got the phone in Downloading mode I unplugged USB from my comp and started odin3 1 click and replugged USB in captivate and low and behold! Odin3 1 click FOUND a yellow port! hurray!
    PROBLEM!
    I clicked START on odin3 and I have been waiting for almost an hour now..I do not see any progress bars on my phone or computer.
    I know that the last time i used one click it did not taker THIS long.
    Looking for advice.
    ty!
    Y!S
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    What exactly are you trying to flash that isn't ODIN 1-click or ClockworkMod flashable?
  1. Gps issues validated...
    Last Post: 08-18-2010, 09:54 PM
  2. Motorola Droid 2 vs Samsung Epic 4G vs myTouch 3G Slide
    Last Post: 08-11-2010, 03:38 PM
download integrate package for odin
htc thunderbolt odin3
odin 1-click download
odin 3 fill in
odin 3 help
odin work in surface
odin3 1.0
odin3 download captivate
odin3 for surface
odin3 full
odin3 help
odin3 not working
odin3 program
odin3 v 1.31 download
unbrick samsung captivate using odin3
