help with att bloatware removal
This is a discussion on help with att bloatware removal within the Samsung Captivate Tech forums, part of the Samsung Captivate category; have no clue what im doing. tried following a guide but when i got to adb shell part it cant find it or recognize what ...
Thread: help with att bloatware removal
    Junior Member cuddles's Avatar
    North Carolina
    have no clue what im doing. tried following a guide but when i got to adb shell part it cant find it or recognize what it is. tried researching apparently not typing in right words someone help please.
    Junior Member monokoter's Avatar
    The only thing I can think of is that if you use third party roms they sometimes remove it for you when you download. But I would not use them with my Captivate. I did it with my old phone ( LG iNcite ) and all AT&T bloatware was gone but that was easy for me to do but these androids are a little bit complicated for my taste.
    deleted by author
    North Carolina
    thanks for the advice yall monokoter i have messed with androids before. i had a motorola droid with verizon i had it hooked up the battery icon was a smiley and when it got low it turned to a mad smiley with horns and then the home button was a green smiley and when u pressed it it winked at you. i can do most of this stuff. and i used 3rd party roms but its that one point that i get to on my comp and it says nope cant recognize it. so i cant get past that one point. ggrr.
    thanks marvin will definitely check into titanium backup
at&t samsung galaxy s2 remove bloatware
att galaxy s3 bloatware
att galaxy s3 remove bloatware
att s3 bloatware
disable at&t navigator
disable att navigator from galaxy s2
how to remove at&t navigator from galaxy s2
how to remove at&t navigator from galaxy s3
how to remove at&t navigator from phone
remove at&t navigator galaxy s2
remove at&t navigator galaxy s3
uninstall at&t navigator galaxy s2
uninstall at&t navigator galaxy s3
uninstall att navigator galaxy 3
