Red SD card Icon?
This is a discussion on Red SD card Icon? within the Samsung Captivate Tech forums, part of the Samsung Captivate category; Does this mean my Internal Storage is getting low. My Internal storage has 1.53G available. The Internal SD has3.58 and my external SD has 0.95 ...
Results 1 to 10 of 11
Thread: Red SD card Icon?
    Junior Member zack.anderson08's Avatar
    Red SD card Icon?
    Does this mean my Internal Storage is getting low. My Internal storage has 1.53G available. The Internal SD has3.58 and my external SD has 0.95 available. Please help this icon is annoying as hell. Thanks.
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Could you post a little more info? Maybe a screenshot? I've never seen that before.
    how do you get a screenshot. I'm fairly new to the phone myself
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    If you have root, then you can grab a screenshot app from the market for free. If not, then I'm afraid it's kinda convoluted. If you're not rooted, could you describe it more?
    Sorry not rooted. The icon looks the same as when you mount your SD card but when mounted its white. This one is red and in the notification drop down it says " Low on space" "database storage getting low"
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Interesting. Database storage is on it's own partition internally. The Captivate has 16GB of internal NAND memory, and it's divided into 2GB for ROM which is where your /data partition is located, and 128 of it is shared with 384MB of RAM to make a total of 512MB... the rest is user accessible storage in the amount of 13.1GB.
    If it's saying your DB storage is low... either there is an issue with the file system, or you have a LOT of apps installed.
    Try this:
    Turn your phone off.
    Hold down both volume keys WHILE pressing the power... you have to hold the volume keys down a bit longer than power.
    Now you'll see Samsung's Android recovery...
    Use the volume keys to move down to "delete cache data" (make sure to NOT hit clear User data, or it will wipe all your personal data)
    Now press the power key to select.
    The process only takes a second, now you can reboot it.
    What that does is clear out Android's cache files, and it will rebuild them at the next boot, so it may take a minute or longer to boot.
    Cool I will try that
    OK tried it and its still there. Any other ideas. I only have 4 pages total of apps including the factory ones
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by zack.anderson08 View Post
    From here, I'd say that that warning will turn into an issue here soon. Memory space is finite.
    You could try reflashing stock 2.1, because if it's an issue with the file system just factory restoring won't help and you'll get that same error after a while. (after backing up your apps and such)
    How do you reflash it. Will I lose all my pics and music
database storage getting low samsung
database storage is getting low what can i do for my samsung captivite
database storage low samsung captivate
galaxy s database storage is getting low
how to get the red database storage symbol off
red sd card icon
red sd card icon android
red sd card icon on samsung galaxy
samsung captivate database storage getting low
samsung captivate database storage is getting low
samsung captivate low on space
samsung captivate low on space notification
samsung captivate red sd card symbol
samsung database storage is getting low
samsung red sd card symbol
