Wifi won't connect unless phone is rebooted
This is a discussion on Wifi won't connect unless phone is rebooted within the Samsung Captivate Tech forums, part of the Samsung Captivate category; This problem cropped up a couple months ago or so. When I try to connect to Wifi, it usually will SAY it's connected (has the ...
Thread: Wifi won't connect unless phone is rebooted
    Junior Member nechalo's Avatar
    When I try to connect to Wifi, it usually will SAY it's connected (has the icon on the top bar) to a wifi network but I will have no internet.
    For example, if I am outside wifi range (say, on 3G) and move within wifi range the phone will "connect" to wifi but I will no longer have internet.
    If Wifi is disabled in settings, and I enable it, Wifi will say it's "connected" but I will have no data connection.
    The only way to get wifi is to shut the phone off and turn it back on. For whatever reason, if it ONLY connects to Wifi from startup, it almost always work. This problem happens with all the wifi networks I've used.
    It seems to be something about going from 3G to Wifi that gives problems.
    Has anyone else had this problem or know what I could do to fix it?
    The phone is rooted and I have Super User Permission. I think this started happening when I was trying to get a leaked version of froyo onto it (it still has eclair, I think). I have since reinstalled everything myself with no luck. The guys at the AT&T repair center reset the whole phone took everything off but Super user permission it seemed) but still has the same problem.
    Junior Member georgiaed's Avatar
    I have the same problem. Yesterday it became the dreaded "unable to scan network" error which eventually--at Samsung tech's suggestion--drove me to have the phone replaced (it is only a week old). They replacement doesn't have the "unable to scan" bug, but it still fails to access the internet despite an excellent connection. Another network gives me the same woes.
    Here's an earlier thread on the subject: http://www.attdroids.com/forum/samsu...t-working.html
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Can you post what type of WiFi network you're trying to (encryption wise) connect to and what your signal strength is?
    I'm using a linksys G router with WPA and the phone shows the signal strength as excellent.
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Go into the WiFi settings on the phone once it looks like it's connected, and manually set the DNS addresses.
    You can try OpenDNS if you'd like: 208.67.220.220, 208.68.222.222
    or GoogleDNS: 8.8.4.4, 8.8.8.8
  1. Help!!
    Last Post: 01-06-2011, 10:48 PM
android phone says it's connected to wireless but i have no internet
att samsung galaxy s3 unable to scan networks fix you tube
captivate is connected to wifi but wont display web pages
captivate unable to scan networks
captivate wifi wont turn on
galaxy s4 wontscan for wifi
motorrola blur won't connect to wifi
samsung captivate no wifi
samsung captivate unable to scan networks
samsung captivate unable to scan wifi
samsung captivate wont scan wifi
samsung galaxy captivate connected to wifi but no internet
samsung s3 att wont display wifi networks
unable to scan error in samsung captivate
unable to scan network galaxy s3
