Bad battery?
This is a discussion on Bad battery? within the Samsung Captivate Tech forums, part of the Samsung Captivate category; Is it normal for the battery to only last 4 hours? I have done the items in the post to help this problem but my ...
Thread: Bad battery?
    Junior Member deb410s's Avatar
    Bad battery?
    Is it normal for the battery to only last 4 hours? I have done the items in the post to help this problem but my phone still only works for about 4 hours. This can not be normal.
    How come Iphone can put in a battery that lasts all day?
    should I take my phone to ATT and get a new one? Thanks for any suggestions!
    Senior Member jmgib's Avatar
    Kentucky
    How long the battery lasts depends largely on how you use the phone. I would think under "normal" usage though it should last more than 4 hours definitely. You should be able to get about a days worth of normal usage.
  1. 1.9 ghz kernal for the g2
    Last Post: 11-15-2010, 07:22 PM
  2. Voice Navigation Issues
    Last Post: 09-25-2010, 08:58 AM
captivate battery only lasts a day
samsung captivate battery crappy
samsung captivate battery issues
