Unregistered Device
This is a discussion on Unregistered Device within the Samsung Captivate Tech forums, part of the Samsung Captivate category; Okay I have tried everything under the sun. I can not get around this stupid " Unregistered Device " error on Kies to upgrade my ...
Thread: Unregistered Device
    Senior Member cuneyyy's Avatar
    DFW
    Angry Unregistered Device
    Okay I have tried everything under the sun. I can not get around this stupid " Unregistered Device " error on Kies to upgrade my captivate to official 2.2. I had one of Dorian,s firmware and trust me those very easy to install comparing to official. Why am I trying to go back to official? because I need my phone to be stable. I used my phone in the line of business that I am working so when phone lags for any reason my job slows down. Anyway back to this problem. I reset the phone with ODIN3 then do master reset to wipe everything. I download the KIES for captivate. I even register my device on Samsung website and redo the ODIN3 one click. reinstall the phone drivers use debugging on and off, use kies connection as default or with option when connect. I can not get around this error. Please anybody knows what to do help me. thank you.
    DFW
    Never mind. I am back to JK3. That one is the most stable version of Dorian's ROM. But still I have to restore
    everything every other week. I guess I am going to live with it. Thanks.
    Member peteseiler2010's Avatar
    Hello, I had this same problem when I tried to update my phone to the new stock 2.2
    This is what I used after searching around for a while.
    RESTORE IMEI and Product Code w/o ADB, PC (ALL DONE ON PHONE) nv_data.bin - xda-developers
    I hope it helps!
    DFW
    Quote Originally Posted by peteseiler2010 View Post
    I hope it helps!
    Thank you. I will try it tonight.
  1. Ask And You Shall Recieve: LTE LG Optimus 2X
    Last Post: 01-04-2011, 08:44 PM
firmware version unregistered device
firmware version unregistered device captivate
how to fix unregistered device
kies mini samsung captivate unregistered device
kies mini says unregistered device
kies mini unregistered device
kies mini unregistered device captivate
kies mini unregistered device fix
kies mini update without registering device
kies unregistered device
kies unregistered device captivate
samsung kies register device
samsung kies unregistered device
samsung kies unregistered device fix
