Samsung captivate 2.2 rooting problems
This is a discussion on Samsung captivate 2.2 rooting problems within the Samsung Captivate Tech forums, part of the Samsung Captivate category; Hi. I have tried numerous times to root my Captivate. I keep getting the same message: This is the first disk in a backup set, ...
Thread: Samsung captivate 2.2 rooting problems
    Android Lurker arnele's Avatar
    Apr 2011
    This is the first disk in a backup set, please insert the last disk of this set.
    Can anyone help me with this problem?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by arnele View Post
    Welcome to the forums!
    What are you using to try to root? I've never run the stock 2.2, but they say *here* that it works on 2.2 Captivates.
    Apr 2011
    sorry for taking so long to reply. I went to a store & they rooted it for me.
android forum
how to root captivate 2.2
how to root captivate with 2.2
how to root your samsung captivate that has 2.2 running
problem to root samsung captivate
problems rooting samsung captivate
root captivate 2.2
root cativate 2.2
root samsung captivate 2.2
root samsung captivate 2.2 -superoneclick
rooting captive 2.2
rooting samsung captivate 2.2
samsung captivate root issue
samsung captivate root problem
samsung captivate root problems
