Multiple Problems with Samsung Captivate
This is a discussion on Multiple Problems with Samsung Captivate within the Samsung Captivate forums, part of the Samsung Android Phones category; I am having way to many problems with my galaxy S. It started when i wanted to update the firmware so i could play candy ...
Like Tree1Likes
  • 1 Post By CR6
Thread: Multiple Problems with Samsung Captivate
    Android Lurker ikidxrobot's Avatar
    Jul 2013
    I am having way to many problems with my galaxy S. It started when i wanted to update the firmware so i could play candy crush, im running froyo by the way, and my computer wont even recognize the phone, so i searched for a rooting salution, i have z4root on my phone as an apk file but cant install it because of some security b.s. can i get major help plz!!!
    Sent from my SAMSUNG-SGH-I897 using Droid X Forums
    Super Moderator CR6's Avatar
    Idaho
    224 times
    I'm pretty sure you'll need to update to Gingerbread before trying to root. Go into your system settings and check for an OTA system update.
    I THINK you'll then be able to play Candy Crush once you update your OS.
    Good luck!
    tap`n
    Jul 2013
    yes i updated firmware and rooted the phone now i have a superuser binary update that fails at last process. What do i do?
  1. Multiple problems 3rd Ally in 6wks-READ!!!
    By Angieinfl in forum LG Ally Help
    Last Post: 07-29-2011, 02:33 AM
  2. Samsung captivate 2.2 rooting problems
    By arnele in forum Samsung Captivate Tech
    Last Post: 04-24-2011, 12:15 PM
  3. Google Talk / Multiple account problems
    By bigjsturm in forum Nexus One Tech Issues / Bug Reports
    Last Post: 06-28-2010, 04:35 PM
candy crush apk for samsung sgh - i897
candy crush for samsung captivate
candy crush on samsung captivate
galaxy i897 candy crush problems
how do i download candy crush on my samsung captivate
need an update for sgh-i897 to b able to download candy crush
samsung captivate i897 wont download candy crush
samsung s i897 cant play candy crush
samsung sgh-i897 stock rom download
why cant i download candy crush on my samsung galaxy captivate
why cant i download candy crush on my samsung galaxy s captivate?
why cant my samsung captivate i897 get candy crush
why wont my galaxy s mesmerize play candy crush
why wont my samsung galaxy s captivate play candy crush
will samsung captivate play candy crush
