GPS Problems?
This is a discussion on GPS Problems? within the Samsung Captivate forums, part of the Samsung Android Phones category; Is anyone else having GPS problems? Can't navigate without it!...
Thread: GPS Problems?
    Junior Member carmicor's Avatar
    GPS Problems?
    Senior Member Lendal's Avatar
    I just noticed a little while ago on one of the mobile phone sites that the Captivate does indeed have GPS issues.
    They also said that there was a work around you could do to get it working again while waiting for an OTA update to fix it.
    Unfortunately, I don't have a Captivate and so didn't really make a note of where to find the details. I'm sure you can find it with Google, if you really want to search for it.
    The good news is that there is a fix for it. The bad news is that you'll have to search for it yourself. Sorry.
    Good luck with it.
    Member trevorr77's Avatar
    Twin Cities, MN
    Quote Originally Posted by Lendal View Post
    Good luck with it.
    I tried one of the fixes out there and it didn't seem to help. I am going to do some more work on it today though...
    Junior Member spoonerdee's Avatar
    I did this fix here.
    • Step 1 -- Open menu > settings > Location & Security. Uncheck the box next to "Use Wireless Networks"
    • Step 2 -- Open the dialer (the phone button) and enter the following: *#*#1472365#*#* . Then press "send" to open the Vibrant's LbsTestMode menu.
    • Step 3 -- In the LBSTestMode menu, press “Application Settings” and change “Operation Mode” to “MS Based.”
    • Step 4 -- In the LBSTestMode menu, find “SUPL/CP Settings” and change the SERVER & PORT to supl.google.com and port 7276 (DO NOT use www. in front of supl !)
    • Step 5 -- Reboot your phone.
    • Step 6 -- Open menu > settings > Location & Security. Check the box next to "Use Wireless Networks"
    Before it I could not get a fix at all on my location, directions did not work. After doing it I was able to get a fix instantly, however if I do the voice turn by turn directions it take a min or two to load up all the info then it works perfectly.
    Member SiXes's Avatar
    when I first got mine the gps didn't want to lock, so I got gps tester from the market and it still didn't want to lock. I turned the gps off then back on, opened gps tester and it locked pretty quickly after that and so far I have had no real issues with it. I have read that maybe there's bad first run out there and they will replace it with no questions or hassle, so if it continues I would take advantage of that.
    Junior Member jki659's Avatar
    I got mine the Fri. after they came out and haven't messed with the GPS much other than to turn it off. Since I was sitting in the truck smoking and decided to just test it out I turned it on dialed into the app and within about 20 seconds had a lock with 9 sats and within about 5 meters I shut it down deleted the results afterward. I've done this all day today and the results are pretty much the same So to me it may just be a chip issue but who knows
    Junior Member Looksbetterinred's Avatar
    I picked min up a few days ago and finally got a chance yesterday to mess with the gps. It takes about 45 sec to lock stats but then is spot on! I think I lucked out and got one that actually works!
problems with samsung i897 gps
samsung android gps problems 2.2.2
samsung sgh-i897 gps fix
sgh-i897 gps not working
troubleshooting android gps issues
