Please help me with my captivate!
This is a discussion on Please help me with my captivate! within the Samsung Captivate forums, part of the Samsung Android Phones category; I've used smartphones in the past but this one takes it to a whole new level. I cannot figure out for the life of me ...
Thread: Please help me with my captivate!
    Junior Member Bridgett's Avatar
    I've used smartphones in the past but this one takes it to a whole new level. I cannot figure out for the life of me how to save attachments, such as ringtones and pictures, that I receieve in text and multimedia messages. Am I just that out of the loop or am I missing something?:confused:
    Junior Member smoore00's Avatar
    Quote Originally Posted by Bridgett View Post
    You can try this for SMS instant messages...select the picture by pressing it, then hit the Menu button on the phone. Select Attached items, and then you can Save. I see this working for a picture sent through SMS, not sure how a ring tone from MMS would behave. Check the Menu button on every screen though, there is usually options under there all over the phone. Also this could all be different for you if you are running Android 2.1 Eclair, as I am on 2.2 Froyo and I have already found differences between the 2 on small stuff like this. Good Luck.
captivate can i save messages
how attachment can be saved on samsung captivate
how can i get pictures via text with my samsung captivate phone
how do i find pictures i saved from a text message on my captivate
how do i save photos on my samsung captivte
how do i save pictures from my samsung captivate
how do i save pictures on my samsung captivate
how do you save attachments on a samsung captivate
how to lock text messages on samsung captivate
how to save a pic to ur samsung captivate
how to save a text photo samsung captivate
how to save email attachment on samsung captivate
howto save messages from lockd captivate
saving photo from text on samsung captivate
saving picture from text message on samsung captivate
