Major help!!
This is a discussion on Major help!! within the Samsung Captivate forums, part of the Samsung Android Phones category; I flashed 2.2 onto my captivate and I want to take it back tomorrow to get a replacement!! I need a fresh 2.1 ROM or ...
Results 1 to 8 of 8
Thread: Major help!!
    Member Danhare4's Avatar
    Exclamation Major help!!
    I flashed 2.2 onto my captivate and I want to take it back tomorrow to get a replacement!! I need a fresh 2.1 ROM or I need to know if they will take it anyway with 2.2!!!
    Would bricking my phone make them accept it??
    Senior Member jmgib's Avatar
    Kentucky
    First of all, why are you wanting to return the phone? Secondly, it is possible that they may accept it, but why not just restore it back to factory settings? The steps to do so are on this board.
    It shuts off when it is locked. I tried doing that. I go into the settings and the kernel version and build text is different, they will prob pick that up. I want to find a ROM to take me completly back to stock, like everything.
    Can someone please help!!!!!!!!
    Kentucky
    Since you are such a pleasant person, here, let me do your work for you. Take a look at this thread for the answer to your questions. Next time, if you aren't knowledgeable enough to recover your phone, maybe you shouldn't be flashing unofficial ROMs which may or may not work.
    I'm just saying thank you, this was all I wanted. Nobody would help me. THanks though bro.
    WERA689
    Guest WERA689's Avatar
    Thanks, jmgib. :cool:
