Am I using 3G or Wifi?
This is a discussion on Am I using 3G or Wifi? within the Samsung Captivate forums, part of the Samsung Android Phones category; So far, I've only been using my new Captivate at home on my Wifi... 3G only came on when I access the market. Now it's ...
Thread: Am I using 3G or Wifi?
    Junior Member timbuk2's Avatar
    Oklahoma City, OK
    So far, I've only been using my new Captivate at home on my Wifi... 3G only came on when I access the market. Now it's started staying on. With a limitation now on my data usage, I want to be assured that 3G is not using it up. I noticed once, I tested it on 3G with Wifi off and saw little, red up & down arrows flashing on the 3G icon, is that the only time it is actually moving data? When I turned Wifi back on, the 3G stayed lit, but didn't notice the red arrows up & down.
    Would I just go to the Market and search for 3G watchdog?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    If you don't see the little arrows flashing up or down, then data isn't being sent over 3G. The 3G comes up when you access the market, because the market checks to see what network you're on, and offers carrier customized results based on the network fingerprint. That's how AT&T blocks certain apps out of the Android Market, like PDANet, which is a tethering app. Usually if you can't find an app, you can put your phone in airplane mode, or in extreme cases, remove your SIM... then everything in the Market is shown because it can't get cellular network information then.
    Oklahoma City, OK
    That's interesting, thanks. I noticed that I could only find one local news station here that I could use and view the videos... one says Java has to be enabled (which it is) one, the videos never load after is prompts me to view in Browser or Video Player (Video Player only plays back the audio) then I found one that actually downloads the videos first from the browser, then I have to double click, .exe/play it. You'd think one of them would steam it. On the one that works, I noticed a link to install a widget for them on my desktop but phone blocked it. A lot of peculiar stuff here when your used to surfing the web on a laptop.
    Oklahoma City, OK
    Quote Originally Posted by Dorian View Post
    Another curious note, when I switch to airplane mode, it disconnects from wifi and 3g (all wireless connections) then I have to re wifi, is that what you mean?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by timbuk2 View Post
    Of course the AT&T default firmware blocks lots of things.
    Yep. Airplane mode cuts off all radios, but then you can manually re-enable the ones you need like WiFi. Meanwhile cellular will stay off until you take it off airplane mode.
    Junior Member emscapt47's Avatar
    FYI i tried that with the no sim card and all it did for my phone was make it none working...Not sure whats up but i tried it..
    Senior Member jmgib's Avatar
    Kentucky
    Then you didn't do something correct. When you remove the SIM card you should still be able to connect to Wifi to access the market.
  1. Help!!
    Last Post: 01-06-2011, 10:48 PM
am i in 3g
am i on 3g
am i on wifi or 3g
how can i tell what wifi i am on with a galaxy 4
how can you tell if your android is using wifi
how do i know if i am using wifi or 3g
how do i know if i'm using android lollipop
how do i know if my droid is using 3g or wifi
how do i know if my droid is using wifi or 3g
how do i know if my phone is using wifi
how to tell if android is using wifi or 3g
how to tell if your phone is using wifi or 3g
is my phone using wifi or 3g
l2 g2 how do i know if i'm on wifi?
on my samsung 3 how do i know im on wifi
