Pictures in MMS messages problems???
This is a discussion on Pictures in MMS messages problems??? within the Samsung Captivate forums, part of the Samsung Android Phones category; Hi all, I looked around in the forums, but I had no luck. Has anyone else encountered any problems trying to send a picture via ...
Results 1 to 8 of 8
Thread: Pictures in MMS messages problems???
    Junior Member jdephilly's Avatar
    Hi all,
    Has anyone else encountered any problems trying to send a picture via MMS on their captivate?
    Mine never seem to send. I always get a "FAILED" message.
    Regular text messages are fine.
    I am currently running the stock version of FroYo.
    Any assistance would be greatly appreciated.
    I also looked on a few other forums, but there weren't really any answers there.
    Thanks
    jay
    Junior Member t3chn0s1s's Avatar
    Concord, CA
    Honestly, I have never had ANY issues sending picture messages with my Cappy when I was running Froyo. I know this may sound like a pain but you might consider a factory reset and flashing back to 2.1 Eclair and reflashing 2.2 Froyo. I had an issue where my accelerometer just suddenly stopped working and I backed up everything, did a factory reset and reflashed my ROM (I was and still am rooted, however so I used Titanium BU to back up). Again, I know you probably don't wanna go thru all of that but sometimes a factory reset fixes any anomalous firmware issues.
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    It could also be your APN settings that are messed up. That would cause no MMS messages to go through when everything else still works. You can check your settings in Settings-->Wireless and Network-->Mobile Networks--> APN Settings
    All your MMS settings should be in there. You can try making a new APN configuration by tapping menu and create a new one... then just fill in the blanks with this:
    APN: wap.cingular
    Proxy: leave blank
    Port: leave blank
    Username:WAP@CINGULARGPRS.COM
    Password:CINGULAR1
    Server: Leave blank
    MMSC: http://mmsc.cingular.com
    MMS Proxy: wireless.cingular.com
    MMS Port: 80
    MCC:310
    MNC:410
    APN Type: leave blank
    Anything not listed above, just leave blank. You may also have to restart your phone after modifying any APN settings, so that they stick.
    Thank you for the info....
    It seems that my APN Settings, cannot be modified...
    Looks like I'll have to find another way around.
    I was rooted with eclair, but with FroYo, I figured I'd wait, because I thought Gingerbread was right behind it....
    I know as soon as I root, Ginger will come out...
    oh well..
    thanks again for the quick responses!
    j
    Concord, CA
    Well there is a semi official GB release for the Cap out now so I'm sure the official release is right around the corner.
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Yep. There is an official Gingerbread release out for the Captivate. It's Android 2.3.3, but it's officially AT&T branded with an AT&T modem. It's not a shipping firmware, but it's stable, and would be fine for daily use.
    Concord, CA
    I will stick with Serendipity VII which is quite stable and doesn't have all the AT&T bloatware. Thank you! Lol
    Junior Member ladydee1222's Avatar
    llllll
  1. YouTube?
    Last Post: 08-21-2010, 02:50 PM
andriod concord downloading pictures
att picture text problems
att pictures not downloading mms
backflip apn att settings#gsc.tab
datpiff app
how do i send pics via mms on my concord android
how do i send picture messages on a t mobile concord?
how to save pictures from picture message on concord android
how to save pictures to android concord
how to see text message photos on samsung concord
samsung captivate no mms
samsung captivate not downloading picture messages
samsung fascinate picture message problem
t mobile apn and mms settings for concord
youtube samsung captivate problems with sending pictures through mms
