My Epic 4G will not display main menu in landscape mode
This is a discussion on My Epic 4G will not display main menu in landscape mode within the Samsung Epic 4G Tech forums, part of the Samsung Epic 4G category; Is there a setting I'm missing? when I put the epic 4g on it's side, the main menu does not rotate until I open an ...
Thread: My Epic 4G will not display main menu in landscape mode
    Junior Member pkellner's Avatar
    Is there a setting I'm missing? when I put the epic 4g on it's side, the main menu does not rotate until I open an app. Is this how it is suppose to work?
    Junior Member BaltimoreEpic's Avatar
    Same problem
    I am also having the same problem. It seemed to work the first day (I noticed because more apps fit on the screen) and now it doesn't.
    Junior Member kspr66's Avatar
    Mine does not change either. I went into settings and changed the orientation so that it automatically changes when rotating phone but the main screen does not change.
    Android Addict jak89's Avatar
    Are you sure this is an option? A lot of home replacements allow you to rotate the home screen but i thought the stock launcher allows rotate but not on the home screen.
    This morning I was responding to a text message using qwerty keyboard. Closed the messaging back to main menu. While the qwerty keyboard is open the main menu will be landscape. I remember seeing a video on the phone that talked about the landscape mode with the qwerty keyboard. I am not sure why you have to open the keyboard to get to landscape, but thats how it works on mine.
    Junior Member d32un3d's Avatar
    3 days after my Sprint 30 day waranty expired, my Epic mysteriously did the same thing. my main menu will no longer convert to landscape unless i have the keypad opened...& sometimes when i'm holding it vertically, my screen will momentarily start in landscape, but 180-degrees/filpped in the wrong direction.
    i've only had this problem since Fri (3/25 ~ same day my waranty expired) when my Epic had its 1st software update. could this B the issue behind the landscape-vs-portrait issues? any other suggestions? did i just waste $350 on this not-so-smart phone?
    other than this new issue i totally love this phone! hope there's a solution out there...
  1. Adjust unlock time
    Last Post: 10-24-2010, 01:05 AM
android exhibit home screen horizontal
android menu landscape
epic 4g landscape mode
epic 4g wont rotate
epic screen doesnt turn on its side
how to get to menu in samsung epic
how to put home screen on landscape mode on samsung
how to set home screen on samsung epic
my samsung epic screen wont rotate to portrait
remove apps from epic 4g mainmenu
samsung epic orientation
samsung epic screen won't rotate
screen wont rotate on ipad
why doesnt my samsung epic rotate back vertically
