Samsung Epic 4G Main Menu Problems.
This is a discussion on Samsung Epic 4G Main Menu Problems. within the Samsung Epic 4G Tech forums, part of the Samsung Epic 4G category; Hello, I purchased my Samsung Epic 4G Sprint a few days ago. I want to know how to delete applications from my main menu without ...
Thread: Samsung Epic 4G Main Menu Problems.
    Junior Member Zandandido's Avatar
    Hello, I purchased my Samsung Epic 4G Sprint a few days ago. I want to know how to delete applications from my main menu without delete the application all together. For example I have contacts on the main menu and on the bottom of the screen as a default with "phone, messaging, and applications". So how do you delete applications from the main menu of the phone without deleting the application all together?
    Junior Member MrRioLoco's Avatar
    I understand that the Main Menu (7 view screens) simply hold applications and widgets there as shortcuts. If you simply hold your finger on the application for a second, It will either let you move the widget or application to a new location, or you can drag it downward to the trashcan Icon that appears and it will remove it from the main screen, but should be still available in your applications or widget menu. You would need to uninstall separately with an uninstaller app, or use the uninstall function built into some applications and widgets. That is my understanding.
    MrRioLoco. I have one thing to say. I love you! Thank you so much, I had so many problems with that.
  1. E-mail setup: HELP ME PLEASE!!!
    Last Post: 11-12-2010, 03:11 PM
  2. Help--I have two problems!
    Last Post: 09-03-2010, 08:59 PM
default apps on samsung epic
how do i remove applications from the samsung epic screen
how to delete applications screens on sprint samsung epic
how to delete phone icon on epic
how to get your home screen to move on samsung epic
how to remove app icons at the bottom of screen on epic
how to remove icon from my epic phone
how to uninstall default programs on samsung epic
howw do i delete defallt apps from my samsung epic 4g
main apps delete from epic
menu problems with epic
samsung epic 4g delete apps
samsung epic 4g issue with main applications at bottom
samsung epic menu issues
where is the main menu in epic located
