Setting default ringtones
This is a discussion on Setting default ringtones within the Samsung Epic 4G Tech forums, part of the Samsung Epic 4G category; Just got my Epic about a week ago...my first android...so be gentle, I'm a beginner! I downloaded Zedge for additional ringtones and downloaded the ringtone ...
Thread: Setting default ringtones
    Android Lurker Matrix's Avatar
    Apr 2011
    Just got my Epic about a week ago...my first android...so be gentle, I'm a beginner! I downloaded Zedge for additional ringtones and downloaded the ringtone I wanted.
    1. I go to settings>sound & display>notification ringtone
    2. Select Zedge ringtones
    3. Select the ringtone
    4. Select Set Ringtone
    When I get a text message, it still plays the ringtone from the defalt android list. Sorry, I'm sure this is a dumb question but what is the secret?
    Apr 2011
    Figured it out...I needed to go to the settings from the Messaging app and set it there.
    Android Addict jak89's Avatar
    Trust me my friend its never a dumb question. If you seen some of the whoppers i have asked in the past.... Glad you worked it out
    Build: Fresh Evo 3.2.0.0 By Flipz
    Kernel Version: King-havs-OcUverik@Ubuntu#9
    Phone: Htc Evo 4g Proud owner 6/4/10
    Over Clocked to 1.2ghz
    ADW.Launcher
    ClockworkMod Recovery
    Unrevoked 3.2
    You i balling me or you just like my Evo
    Senior Member rich_c's Avatar
    Also remember that if your phone is plugged into your computer and the SD card is not available, NONE of your custom ringtones will work.
    I gave my iPhone to my 5 year old and got an EVO.
default ringtone 1 epic 4g
download samsung ringtone default
how to change ringtone on samsung note
how to change samsung note ringtone
how to change your default ringtone on samsung epic
samsung default ringtone
samsung default ringtone download
samsung default ringtones
samsung default ringtones download
samsung default tone download
samsung epic 4g default ringtone change
samsung epic default ringtone
samsung epic preset ringtones
samsung note change default ringtone
samsung standard ringtone download
