how do I move things from my internal hard drive to my external hard drive?
This is a discussion on how do I move things from my internal hard drive to my external hard drive? within the Samsung Epic 4G forums, part of the Samsung Android Phones category; I know there are programs I WANT on my internal hard drive, I'm not sure which ones can't be moved (or shouldn't be moved). Is ...
Thread: how do I move things from my internal hard drive to my external hard drive?
    EpicForums.net Member Epic Forums User's Avatar
    I know there are programs I WANT on my internal hard drive, I'm not sure which ones can't be moved (or shouldn't be moved). Is there a program I need?
    I tried to achieve this using the usb hookup but nope, didn't offer me anything that looked right.
    If you want to move applications from your internal ROM memory to your external micro-sdhc card you have to wait until the Froyo 2.2 Android is available on the Samsung Epic (which should be available by the end of this month). After your upgrade your Samsung Epic to Froyo 2.2 you will be able to move items installed in your internal ROM memory to your SD card from within applications settings. See the article below:
    How to Move Apps to SD Card in Google Nexus One and Motorola Droid | Mobile-Geeks
android tablets internal hard drive
how can i move things from an internal hard drive to an external hard drive
how do i move things on my droid to the sd card
how to completely wipe internal harddrive on samsung epic
how to completly wipe the samsung epic
how to move things to a hard drive
in android which folder is my external card
move things to sd card
my tablet internal drive
nexus one how can i move things to the sd card
samsung android move apps microsdhc
samsung epic 2.2 how to move things to sd card
sprint epic how do i move internal hard drive to sd card
using samsung epic as harddrive
why should i move applications to my sd card
