Invisible Cell Phone Protector Shield Full Body Skin for Samsung Epic 4G
This is a discussion on Invisible Cell Phone Protector Shield Full Body Skin for Samsung Epic 4G within the Samsung Epic 4G forums, part of the Samsung Android Phones category; Skinomi TechSkin goes beyond traditional screen protectors, skins, covers, and cases. This cell phone protector is made from clear thermoplastic urethane film - the same ...
Thread: Invisible Cell Phone Protector Shield Full Body Skin for Samsung Epic 4G
    EpicForums.net Member Epic Forums User's Avatar
    Skinomi TechSkin goes beyond traditional screen protectors, skins, covers, and cases. This cell phone protector is made from clear thermoplastic urethane film - the same film used to protect military aircrafts and NASA space shuttles. It has the ability to resist high levels of abrasion, making it the ultimate protector for gadgets and devices. The film "scratch-proofs" your device without adding bulk like traditional cases. Skinomi TechSkin is designed to provide lifetime protection for your device. If the film ever wears or scratches, Skinomi will replace it for free, for as long as you need it for your device. If you ever need to remove the TechSkin, it peels off easily leaving no residues unlike other screen protectors or skins.
    For more information visit: Amazon.com: Skinomi TechSkin - Invisible Cell Phone Protector…
    Phantom Skinz is the latest in Optically Clear Protection for Personal Electronic Device’s (PED’s). Exclusively designed for your Samsung Epic 4G (Galaxy S) Pre-Order, Phantom Skinz will provide Superior protection against “everyday” scratches, dings and debris. Our design team has years of experience and balances “maximum coverage” against “ease-of-installation” to give YOU the optimal combination. Simple and easy to follow instructions assure you that your Samsung Epic 4G (Galaxy S) Pre-Order will maintain that “like new” look.
    Phantom Skinz are made from Durable “Self Healing” film technology that allows most dings and scratches to “heal” after a 24 hour period.
    Additional benefits:
    • No need for removal when using a docking station
    • Touch Screens work exactly as if not covered at all
    • Screen cleaning is a snap
    • Does not alter the manufacturers look and design
    Phantom Skinz |Samsung Epic 4G, cell phone skins, screen protectors, cases, covers, shileds, full body protection
    The Invisible Gadget Guard is the best way to protect your Samsung Epic 4G! Composed of optically clear military-grade film typically used to protect equipment and vehicles, the Invisible Gadget Guard stands up against everyday wear and tea
    samsung phone covers
android forums protective case epic 4g
best case for samsung epic
best epic 4g skin
cellphone full body skins
epic 4g body guard
full body skin cell protector for epic 4
invisible shield self healing#gsc.tab
phantom skinz samsung epic
samsung cell phone skins and covers
samsung epic phone covers
samsung epic skins
samsung phone skin covers blogs
samsung phone skin forums
samsung skin cover forums
techskin cellphone protector android forums
