EpicForums.net Member
Car and Home 2 in 1 Combo Charger for the Samsung Epic 4G - uses Gomadic TipExchange
The Samsung Epic 4G Car and Home 2 in 1 Combo Charger with TipExchange is the essence of an all-in-one charging solution for all your travel needs. Designed to function as a high quality Rapid Car charger via a standard DC vehicle cigarette lighter the convenience does not end there. Two fold-able AC outlet power pins easily emerge from the compact base to seamlessly convert the charger to a Rapid Wall AC charger too! Built with the convenience of Gomadics TipExchange the same 2 in 1 Combo Charger can also be used to charge your other gadgets by simply switching the tip (additional tips sold separately). If travel is in your future a Gomadic Combo Charger should be packed in your travel bag.
For more information check out: Amazon.com: Car and Home 2 in 1 Combo Charger for the Samsung Epic 4G - uses Gomadic TipExchange Technology: Electronics
08-05-2010 06:34 PM
# ADS
Dan is always bringing us the new apps and accessories!
