Battery life
This is a discussion on Battery life within the Samsung Epic 4G forums, part of the Samsung Android Phones category; Can someone tell me how to conserve battery Sent from my SPH-D700 using Android.net...
Thread: Battery life
    Android Lurker Kendrickroad's Avatar
    Battery life
    190 times
    FurryVarmint
    Please do not cross post. Your other thread has been closed.
    Sent from my Droid using Android.net
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    67 times
    Try not using WiFi or video if your out and about. You can also unsync your google account and turn off GPS until you need it. Just to name some ways.
    Android Lurker technopeasant's Avatar
    Apr 2011
    I go to settings a lot turn everything off that isn't needed. I also have JuiceDefender looking after things, though I'm not sure it's any better than what I can do myself. GPS, wifi, bluetooth, etc., suck up battery power. I use Airplane Mode, too, if not using the phone as a phone. I'm usually sort of heavy handed here, since most apps that need something turned on will tell me so.
    You can turn down your screen brightness to the lowest level you can tolerate. The "auto" setting may do this okay, but at night, i find that a lower setting is better.
    If your phone is rooted, consider an overclock app such as QuickClock, and then, contrary to the 21st century dictum of speed = good, underclock the CPU. I'm running my 1000mhz CPU at 800mhz. So far, the speeds have been fine.
    Get a bigger battery, or build a battery pack that can supply a couple of extra charge cycles. I use 4 AA NiMH batteries attached to a home-made usb dongle. Is good for two charges (charging the battery from 50 per cent up to 100 per cent).
    Android Sr Member jon_l85's Avatar
    wisconsin
    I download a battery-saver off the market called "Green Power Free." It works amazing on my Ally so give it a shot and let me know how it works!
    Sent from my Ally using Android.net
    Android Lurker sfjmcblade's Avatar
    Download juice defender from the market and turn off data by pursuing and holding the power off button for three seconds.you will have no problem with battery life after this! Then just turn on data only when you need it
    190 times
    FurryVarmint
    Juice defender is useless. There's nothing it can do that you can't do manually, and by doing it manually you're not hitting the battery up by having a process running all the time.
  1. HTC Inspire 4G Battery Life
    By danDroid in forum HTC Inspire 4G
    Last Post: 10-10-2011, 08:17 PM
  2. Low battery life
    By cybersenior in forum Samsung Intercept
    Last Post: 03-19-2011, 04:19 PM
  3. [HOW TO] Optimize Battery Life
    By WugFresh in forum Android Forum
    Last Post: 01-19-2011, 09:14 PM
  4. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
  5. Battery life is terable
    Last Post: 09-04-2010, 09:36 AM
android sphd700 battery issue
do you need to download battery saver on samsung droid charge
droid incredible battery life
epic battery saver
how to conserve battery life on a android nexus 4g
how to conserve battery life on inspire?
how to improve battery life on my nexus s 4g
how to improve battery life on samsung epic
how to save battery on epic
increase battery life sph d700
overclock samsung intercept
samsung epic battery saver
samsung intercept overclock
sph d700 conserve battery
what are some ways to save my htc inspire 4g battery
