Android Lurker
Samsung Galaxy Ace Headphone Issue
I recently bought a samsung galaxy ace as an upgrade from my previous LG Optimus (Terrible phone) and i seem to be having trouble with earphones in it. It came with the same pair that comes in Galaxy S's although it is TERRIBLE and i will repeat TERRIBLE quality, there is hardly ANY sound. I tried it on a galaxy S and what do you know, fantastic quality.
Please i would really appreciate any help given on here.
06-06-2011 03:41 PM
# ADS
Super Moderator
Even though they worked well on a different device, have you tried a different set of earbuds just to confirm? Typically, earbuds that come free with most phones and/or tablets aren't the best quality.
(Worth a try)
You may also want to double check your device... most phones with 2.2 and higher have a seperate volume control for "system" and "media".
Tapatalker!
Super Moderator/RS
I agree with CR6. It probably is just the volume turned down. Yeah the free earbuds are not always the best.
Android Lurker
I tried changing the buds, no different, and as to the volume control i have them set to maximum. No change? Also it sounds a little different when i hold the phone button down on the mic attatched to the cable.
Super Moderator/RS
Sounds like you have a faulty jack. See about getting a replacement phone.
DO NOT WRITE IN THIS SPACE
Android Lurker
I tried some other headphones, they work fine? But they arent the best of earphones, plus i just tried the samsung ones on my computer and they're the same.
Super Moderator/RS
They all sound the same on the pc? Sounds like one of them may have a slightly longer/shorter plug than the others. It's making better contact inside the jack.
Sent from my Droid using Android.net
Android Lurker
No no, just the samsung ones sound the same, even on my ipod. I am really stumped :/
Super Moderator/RS
The samsung headphones sound bad everywhere? I'm confused.
Android Lurker
Lol, i found this topic via google, searching for the solution.
Anyway i have exactly the sam issue. Awful sound quality on samsung original headphones. It gets little better when i press th button on them. Other headphones sound OK.
Looks like we got some failed earphones lolol.
PS sorry for my english
