problem connecting to wifi, gps
This is a discussion on problem connecting to wifi, gps within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; Hi,
It seems that after I have used my phone for a while (1-2 days), the wi-fi and gps (not too sure about bluetooth) will ...
Android Lurker
Hi,
It seems that after I have used my phone for a while (1-2 days), the wi-fi and gps (not too sure about bluetooth) will display an 'error' when I try to connect, even though I do have wi-fi hotspots / am out in the open. The only way I've found to fix this is to reboot the phone, but the problem continues to occur and I have to reboot my phone every other day.
This is rather annoying as every time I reboot my phone all my apps are rearranged (or is there some way to get around this other problem as well?)
Help on these issues is greatly appreciated!
Android.net is the premier
Android Lurker
Hi! I have the same problem. Have you solved yours? (besides rebooting)
Thanks!
Android Enthusiast
Do you and kingsolomon have the same kind of phone?
Android Lurker
Originally Posted by
titanoman
yes, it's a samsung galaxy ace s5830.
Super Moderator/RS
Does an airplane-mode cycle help or not? Are you running any kind of task killer?
DO NOT WRITE IN THIS SPACE
Android Lurker
furbearingmammal
Sorry, but I don't know what you mean about an airplane-mode cycle. If it is just to turn on and off the airplane mode and check if something changes with my GPS reception I just did it and nothing happened. I'm using GPS Test app to check the GPS reception and it is always 1 or 2 in view and 0 or 1 in use (and the strength is always below 40).
And no, I'm not using any kind of task killer.
What do you think I should do?
Thank you!
- You may not post replies
- You may not edit your posts
Forum Rules
By Engwathang in forum Huawei Ideos X5
Last Post: 02-15-2012, 10:35 AM
By dolah in forum Acer Liquid
Last Post: 10-09-2011, 02:16 AM
Last Post: 06-09-2011, 12:13 AM
By Drew Clifford in forum Rescue Squad Help
Last Post: 05-16-2011, 07:20 PM
By Jef-Droid in forum Motorola Droid X
Last Post: 02-14-2011, 10:42 PM
galaxy ace gps error
galaxy ace gps problem
galaxy ace wifi error
galaxy ace wifi error fix
galaxy ace wifi problem fix
how to fix samsung galaxy ace wifi error
samsung ace gps not working
samsung ace wifi error
samsung ace wifi problem
samsung ace will not connect to gps
samsung galaxy ace gps problem
samsung galaxy ace s5830 gps not working
wifi error on samsung galaxy ace
wifi samsung ace error
