Loss connection WIFI
This is a discussion on Loss connection WIFI within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; [SOLVED] I changed my router for a new one and it works! Now I have a ZiXEL and previously it was a Xavi. Thanks a ...
Results 11 to 13 of 13
Thread: Loss connection WIFI
    Android Lurker Fri's Avatar
    [SOLVED]
    Now I have a ZiXEL and previously it was a Xavi. Thanks a lot for your answers. :D
    197 times
    FurryVarmint
    Glad to hear you solved the problem!
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    Glad it is working for you.
  1. Losing wifi connection - Batch gh69-12988a
    By bjovas in forum Samsung Galaxy S2
    Last Post: 01-19-2012, 12:37 PM
  2. connection via httpconnection
    By jaydee in forum Android Forum
    Last Post: 07-20-2011, 02:30 PM
  3. Signal loss when sending a text.
    By Uptheirons726 in forum HTC G2
    Last Post: 05-29-2011, 01:28 AM
  4. WIFI connection
    By jlm226 in forum Android 2.2
    Last Post: 04-21-2011, 06:20 PM
  5. PS3 Tether Connection
    By Angered_Link in forum Samsung Epic 4G
    Last Post: 02-20-2011, 12:58 PM
ace keeps losing wifi
android 4.2.2 samsung galaxy s3 loses wifi
disabled/disconnected wifi in samsung galaxy ace
galaxy ace cannot connect to wifi
my galaxy tab4 connects then imediatly disconects from the wifi
samsung galaxy ace cant connect to wifi
samsung galaxy ace disconnects wifi
samsung galaxy ace wifi disconnect
samsung galaxy ace wifi keeps disconnecting
samsung galaxy ace wifi out of range
samsung galaxy ace wifi problem fix
why does my galaxy ace loose wi fi code
why does my samsung galaxy ace keep losing wifi
why does my samsung galaxy ace search for wifi but lose signal
why samsung ace disconneted
